LabWindows/CVI
Distributing the application
Hi all,
I have a problem with distributing my application using CDK. My hardware configuration comprises one PCI DIO card, one Agilent 54622D scope running through NI 488.2 GPIB.
I build and run my application without any errors in debug mode (CVI 7.0). Then I create the executable, that also run ok.
When I create my distribution kit with the options that can be seen in the attached file and install to a new machine (on which CVI 7.0 is not installed..), I see the error message "LWTCPJSOCKWNDYCLASS:HBIC.exe - Application error" The Application Failed to initialize properly (0x0c0000142).
If I install the application to any machine that has CVI 7.0 installed on it, it runs properly.
Requesting urgent help about this issue.
T
hanks in advance
BR
Engin Ozturk.
(3,394 Views)
The CVI distribution kit will not distribute the correct drivers for you. You need to make sure that the deployment machine has the NI-DAQ and NI-488.2 drivers installed on it and your devices are configured correctly before running your CVI application. Copying just the driver dlls will not work.
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,394 Views)
