LabWindows/CVI
Display and Store a 8bit greyscale bitmap aquired from a Keyence Camera
Hello.
I'm using a Keyence camera system to get images (8bit greyscale in uncompressed BMP format) from different objects.
After triggering the image capture I want to do several things with the image data:
- transfer it to the LabWindows/CVI PC (this is done with a serial USB connection to the camera system)
- display it to the user as a 8bit greyscale image
- pass the 8bit greyscale image into a third-party function that does some calculations with it (the third party software accepts a double array together with height and width as parameters, so I do have to convert the image data to double)
- save the image to disk
So far I've done this as a first try to get things working (I wanted to create the bitmap, copy it to the clipboard and then display it in Windows Paint):
int ProcessImage(void)
	int hwError = 0; // error code
	int bitmapID = 0; // bitmap ID
	char cvBitmap[2000000] = {0}; // bitmap data aquired from the camera
	int colorTable[256] = {0}; // color table for the bitmap
	hwError = CVCameraGetBitmap(&cvBitmap[0]); // get the bitmap data from the camera
	if(hwError != SUCCESS)
		DebugPrintf("ProcessImage(): GetBitmap failed\n"); // error handling
		return FAULT;
	for(int i=0; i<256; i++) // fill the ColorTable for the bitmap
		colorTable[i] = i;
	hwError = NewBitmap(1600, 8, 1600, 1200, colorTable, cvBitmap, NULL, &bitmapID); // create new bitmap
	hwError = ClipboardPutBitmap (int bitmapID); // copy bitmap data to clipboard
//	DiscardBitmap(bitmapID); // delete bitmap
	return hwError;
When i paste the image in Paint it just displays all black, so I think maybe it's something wrong with the color table?
I didn't manage to get a proper image, though. Maybe one of you can help me out there?
Thank you for your help.
Bernd
P.S. I'm using CVI 9.1
(4,155 Views)
Hi Bernd,
maybe this will help you:
#include <utility.h>
#include <ansi_c.h>
#include <userint.h>
#include <cvirte.h>
static int gHeight;
static int gWidth;
static int bmpID;
int pixelDepth, rowBytes, *colorTable = NULL;
unsigned char *bits = NULL, *mask = NULL;
static int colorSize, bitsSize, maskSize;
int main (int argc, char *argv[])
    if (InitCVIRTE (0, argv, 0) == 0)
        return -1;    /* out of memory */
    GetBitmapFromFile ("c:\\Penguins.bmp", &bmpID);
    GetBitmapInfo(bmpID, &colorSize, &bitsSize, &maskSize);
    colorSize=256;
        if (colorSize > 0)
            colorTable = (int *)calloc(colorSize, sizeof(int));
            bits = (unsigned char *)malloc(bitsSize);
        if (maskSize > 0)
            mask = (unsigned char *)malloc(maskSize);
    GetBitmapData(bmpID, &rowBytes, &pixelDepth, &gWidth, &gHeight, colorTable, bits, mask);
        colorTable[i] = 10000*i;
    NewBitmap(rowBytes, 8, gWidth, gHeight, colorTable, bits, mask, &bmpID);
    ClipboardPutBitmap (bmpID);
    DiscardBitmap(bmpID);
    return 0;
Regards
DianaS
(4,131 Views)
