LabWindows/CVI
Display Time in my GUI
Help please
Hello;
I would like to display on my GUI a time decomter in form (: days: hours: minutes: seconds), I managed to display it on my GUI but the probeleme is that it does not count !?
I would like to know what is the function that allows me to display deducing counter on my GUI
Ps (I send the time from teststand in seconds)
Thank you
(3,235 Views)
There is no automatic means to display data on a CVI panel. If you want to have the clock regularly updated you need some periodic task to do it: if you have a timer control or a periodic thread already active in your program you can add the clock update there, otherwise you can add a timer control for this task.
(3,223 Views)
thanck you
(3,220 Views)
I want to call two functions:
How I will call them in Ontimer?
Thanck you
1) Function 1:
int __stdcall DLLEXPORT MPT_SYS_Display_RemTime_LED (int Index,int Status,int On_Off)
int Return_Value=0;
char CtrlName_LED[100]="";
int ID_LED;
if(Return_Value=CmtGetLock (LockIhmHandle)<0)
return Return_Value;
/* if (Return_Value=Fmt(CtrlName_LED, "%s<%s%d","ALIM_",Index)==-1)
goto Error;
if (Return_Value=GetCtrlName(CtrlName_LED)==-1)
goto Error;
ID_LED=TabResult[CtrlID]; */
if (Status==0)
if (Return_Value=SetCtrlAttribute (TabCtrlTab[tab_Rem][TabHandle], Remaining_Time_Led[Index], ATTR_ON_COLOR, VAL_GREEN)<0)
goto Error;
if (Status<0)
if (Return_Value=SetCtrlAttribute (TabCtrlTab[tab_Bench][TabHandle], Remaining_Time_Led[Index], ATTR_ON_COLOR, VAL_RED)<0)
goto Error;
if (Return_Value=SetCtrlAttribute (TabCtrlTab[tab_Rem][TabHandle], Remaining_Time_Led[Index], ATTR_CTRL_VAL, On_Off)<0)
goto Error;
Return_Value=CmtReleaseLock (LockIhmHandle);
Error :
2) Function 2
int __stdcall DLLEXPORT DisplayRemainingTime (int Index, char as8InputString[])
int Return_Value=0;
//int s32CtrlId;
//GetPanelHandleFromTabPage (pnlE01, PNL_E01_TAB, 1, &iMyTabHandle);
if(Return_Value = SetCtrlAttribute(TabCtrlTab[tab_Rem][TabHandle],Remaining_Time[Index] , ATTR_CTRL_VAL, as8InputString) < 0)
/* if(Return_Value = SetCtrlAttribute(TabResult[TabHandle],s32CtrlId, ATTR_CTRL_VAL, as8InputString) < 0)
return Return_Value; */
/*if(Return_Value = SetCtrlAttribute(TabCtrlTab[tab_All_Test_Lines][TabHandle], s32CtrlId, ATTR_CTRL_VAL, 22) < 0)
3) My function OnTimer:
int CVICALLBACK OnTimer (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
return 0;
(3,208 Views)
If the functions have been succesfully exported by the DLL you should be able to call them easily in the timer control callback, but I cannot help you in interfacing between TestStand and CVI as I don't use TestStand.
(3,199 Views)
