LabWindows/CVI
Display GUI from DLL
HI
How do i display a panel when im creating a CVI dll?
I use the CVI Dll in Teststand and i need to display a panel. e.g. To show a list of com port for the user to select.
Help share your knowlegde
(3,042 Views)
Hi Shako,
You can find an example of CVI GUI being called from TestStand in the TestStand Examples folder. The example is called MultiUUT. It looks like you just need to create a dll that calls the UIR.
I hope this helps.
Josh L.
(3,023 Views)
