LabWindows/CVI
DiscardMenuItem fail error -11
I have a menu that I created in the UI editor and placed on a panel.  I want to programatically remove menu items.  I get error -11 UIEInvalidMenuItemId.  I even tried removing the menu from the panel and loading the menu separately and I still get the error.  When that failed I triedI to set the dimmed atrribute.  That worked.
         iMenu = LoadMenuBar(iMainPnl, "140613.uir", MBR_BADGE);
        iTmp = DiscardMenuItem(iMenu, MBR_BADGE_MOTOR);
     iTmp = SetMenuBarAttribute(iMenu, MBR_BADGE_MOTOR, ATTR_DIMMED, TRUE);
CVI 2012 SP1
(5,324 Views)
This behavior looks correct to me: you can delete menu items or submenus, not menus, that is you need to pass at least a third-level id to the function (menuBarID_menuID_menuItemID or menuBarID_menuID_subMenuID). You can dim a whole menu, instead: every element from the menu that shows on the menu bar up to the last item is dimmed, including all submenus if they exist; other menus in the menu bar are left unchanged).
In your scenario, I suppose MBR is the menu bar ID and MBR_BADGR a menu ID. Menu items should be in the form MBR_BADGR_menuItemID.
By the way, error -1 means "the id passed was not a valid menu item id": you can obtain this descriptive string by calling GetGeneralErrorString passing the error number to it.
(5,314 Views)
Accepted by topic author mjl
Forgot to say that you can use DiscardMenu to delete a menu from the menu bar.
(5,306 Views)
I was using the wrong command.  I see that my probem was that I thought the menu bar was the menu and didn't realize that each primary entry in the menu bar was a menu.
By the way, I was getting error -11 not -1.
Mike
(5,275 Views)
