LabWindows/CVI
Directory History
When I'm in TestStand, the first operation is to load my sequence file.  The folder that TestStand goes to each time isn't the folder where I keep my sequence files.  How do I change the path I use to my sequence files?
Tony
(3,054 Views)
Tony,
First, you may be able to get better answers to your TestStand questions if you post to the TestStand forum that can be found at http://forums.ni.com/ni/board?board.id=330
However, I am a TestStand Applications Engineer and I've been looking into this issue for you.  Unfortunately, there is not a way to get the first item in the Directory History to show anything but the TestStand directory.  I tried to programmatically open a sequence file upon start-up, but the TestStand directory is still the most recently opened item.  I apologize that this is the case.  Let me know if you have any other questions.  Thanks and have a good one.
(3,035 Views)
