LabWindows/CVI
Directory Browser
I would like to add a control "Directory Browser" which select a directory but I do not fin in the menu Create. Is it possible ?
Thanks for your answer.
(4,051 Views)
Does this question mean that your previous request, http://forums.ni.com/ni/board/message?board.id=180&message.id=47324#M47324, was solved?
Concerning your new question: you could use a button control which calls a DirSelectPopup.
(4,045 Views)
Thanks for your answer, yes my previous request is now resolved thanks to you.
Best Regards
(4,042 Views)
Thanks for DirSelectPopup. Now, I would like to memorise the last directory selected between 2 launch of the exe. Use of environment variable or something else ?
(4,037 Views)
I would recommend using the instrument driver for reading/writing ini files. This is a very generic approach and permits saving/retrieveing other settings, too.
(4,033 Views)
Check out this thread, which might help.
--Ian
(4,016 Views)
