LabWindows/CVI
Direct X Sound.
Are there any pointers or examples out there using SDK, Direct X sound?
John Cameron.
(3,511 Views)
There is an example on our website that shows how to play a .wav file with Windows SDK functions at the following link:
http://zone.ni.com/devzone/devzoneweb.nsf/opendoc?openagent&FA98923398CB2FEB8625687F005AE482&cat=86F1ECAEA043C2E6862567A900588436
There is also a company that has created a library for use in CVI to play wave files, they are located at the following site:
http://www.xon.de/eng/products/audio.htm
If you want to do more complex sound playing/file manipulation you might indeed want to use the DirectX8 Audio API that is documented at the following Microsoft Developer Network site:
http://msdn.microsoft.com/library/default.asp?url=/library/en-us/dx8_c/hh/dx8_c/audio_front_4zvz.asp
Notice that v8.0 of DirectX Audio now has a COM based au
tomation interface that you can use the ActiveX library in CVI to create instances of "Audio objects" for sound file manipulation.
Jason F.
www.ni.com/ask
(3,511 Views)
