LabWindows/CVI
Digital Output Generation
I think this will sound pretty basic. I have configured a task for digital output  using my PCI 6013 device as explained in the samples. My question is, the digital level will remain high or low as long as the task is active or should I keep calling WriteDigitalLines() in a loop to keep it high or low? My task is quite simple just put the lines high or low like a switch.
thanks.
(3,194 Views)
Once you set the state of the line it stays that way for the duration until you set it again.
(3,187 Views)
