LabWindows/CVI
Differences between Microsoft RegSetValue and NI RegWriteString
I am trying to write the registry using the function RegWriteString as follows
iLocalFail = RegWriteString(REGKEY_HKCU, "Software\\Custom PDF Printer\\OutputFile", "OutputFile", caFilenameWithPathInfo);  I get a Default and OutputFile under the Custom PDF Printer\Outputfile key, see attachment NI Write.jpg.
When I use the Microsoft RegCreateKeyEx and RegSetValue functions
lReturnValue = RegCreateKeyEx(HKEY_CURRENT_USER, "Software\\Custom PDF Printer", 0, NULL , REG_OPTION_NON_VOLATILE, KEY_ALL_ACCESS, 0, &hKeyHandle, &ulReturnValue);
lReturnValue = RegSetValue(hKeyHandle, "OutputFile", REG_SZ, caFilenameWithPathInfo, strlen(caFilenameWithPathInfo));
I only get the Default value set to the filename, see attachment Microsoft Write.jpg.
The program that I am setting the registry for wants the Microsoft results.  The NI functions make the program cleaner, but why are the results different.
(4,205 Views)
Accepted by topic author Paul_Knight_Lockheed_Mart
Hey Paul -
To get what you're looking for, you just need to pass NULL to the "ValueName" parameter:
NickB
(4,193 Views)
Thanks, that works
(4,179 Views)
