LabWindows/CVI
Developing an application for Windows XP
Are there any compatibility issues with using LabWindows/CVI 2017 to develop applications for Windows XP, Service Pack 2 or 3?  If so, what is the latest LabWindows/CVI version I can use?  I currently am using 2013 SP2, but I'd like something more current.
(3,813 Views)
Based on my experience and tests, the latest version you can use is CVI 2015.
You can use CVI 2015 SP1 only if you don't use VISA and/or DAQmx (maybe other components too, I don't know) but you have to follow this steps.
I know very wellthat this can be an issue, but the best thing is to leave XP (and force the final customer to do the same). Sometimes a hardware change is necessary too, but on the long period is the cheaper solution.
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,781 Views)
To expand on Vix's comment, you will also need to make sure you're using the 2015 SP1 f1 environment if you'd like to build a distribution that can install on XP. Before that version, the minimum OS requirement was also built into the distribution binaries, so the steps in that KB will not help.
https://www.linkedin.com/in/trentweaver
(3,765 Views)
Hmm, unfortunately, I think the application does use VISA, so I guess that option is out.
(3,762 Views)
Could I use LabWindows/CVI 2017 to develop the application, and then build it with 2013 so it runs on XP?
(3,757 Views)
If you are not using any command that do not exist in 2013 you should be able to do this.
But if you keep a 2013 install alive to compile the application, couldn't you use it for development as well?
(3,751 Views)
I could use 2013, but the IDE features are lacking significantly.
(3,744 Views)
