LabWindows/CVI
Determine which files are used by which projects
Good Morning,
is there an easy way to determine which header-, source, .uir files are used in which projects? I have multiple projects using a shared codebase. I would like to see which projects would be effectetd if I make changes.
My current solution is opening the project files but that is fairly prone to errors and takes a lot of time.
Thanks!
(4,236 Views)
I don't know of any built in CVI functionality to do this. There is a handy utility called Dependency Walker for doing pretty much the opposite of what you want, but I don't think there is any kind of "where used" functionality. I suspect this would be a good use case for some kind of source code control. Alternatively, you could just manually track your files in a database.
https://www.linkedin.com/in/trentweaver
(4,214 Views)
Thanks WireWeaver!
I have used Dependency Walker, but in this case I ended up doing something else. Since the project files are basically text files, I opened alle relevant project files with a text editor, copied one after each other to an excel spreadsheet, performed some Excel magic to get rid of all the directory crap and used a pivot table to check which files where used in multiple places. Probably not the most elegant way, but it worked for me and I was able to find all shared files between the projects.
Thanks again and have a good one,
ZerMahlMeer
(4,073 Views)
