LabWindows/CVI
Decoding DeviceNet
Hi
I am currently try to decode DeviceNet.
What im doing is using USB-CAN to see the packets sent to the slave device.
The reason for this is to emulate the function of the DeviceNet PCI card using the USB-CAN.
The following is what the DeviceNet PCI card does before requesting for data infomation.
What i know so far :
Request to go online:
05FF  7  00 38 00 56 42 0F 00
Request to start Device :
07BF  4  03 4B 00 34
07BF  4  03 4B 00 34
Not sure :
041E  6  3F 4B 03 01 01 3F
041B  3  3F CB 00  - Reply from Slave
041C  6  3F 4B 03 01 02 3F
Request For Vendor ID :
041C  5  3F 0E 01 01 01
041B  4  3F 8E 5A 00   - Reply from Slave
Request For Product Type :
041C  5  3F 0E 01 01 02
041B  4  3F 8E 0C 00 - Reply from Slave
Request For Product Code:
041C  5  3F 0E 01 01 03
Not sure :
041C  6  3F 10 05 01 0C 03
041B  2  3F 90  - Reply from Slave
041C  7  3F 10 05 02 09 E8 03
041B  4  3F 90 E8 03  - Reply from Slave
041C  5  3F 0E 05 02 07
041B  4  3F 8E 40 00  - Reply from Slave
041C  5  3F 0E 05 02 08
Can any please help explain to me the parts that im not sure of or point me to documentation which could help me ?
I really apperiate any help.
Thanks in advance.
I have attached the packets i recieved using PCAN View.
Help share your knowlegde
(3,364 Views)
Hi Shako,
Are you just trying to emulate the startup? You may have some issues trying to get the USB-CAN device to be able to work with DeviceNet due to the lack of periodic frames. The PCI-CAN is capable of using CAN Objects to send frames at a constant rate, the USB-CAN does not.
Chris T.
(3,345 Views)
