LabWindows/CVI
Debuging time too long
Hi!
I have a problem with the compilation of my program in debugging mode.
The first time I run my code in debuging mode, it works well.
But the second time (and all the followings), it  takes 15 secondes and CVI is "Not Responding" during this period.
So I would like to know what could be the cause of this problem? Memory leak? Include file?
And it also takes a while when I quit my program after having interrupted it with a breakpoint.
Thanks in advance,
Thomas 1330.
(4,653 Views)
Verify that you don't have lots of variables in the watch windows. How big is you prog and its memory usage ?
(4,616 Views)
My progran is divided into 4 source files and the main one is about 4000 lines.
But now it works well : in fact every time I closed my program, there was some allocated memory (some image structure) that was not deallocated.
And I think this remains of memory took more and more space.
But thanks for your advice.
thomas1330
(4,602 Views)
