LabWindows/CVI
Debugger crashing after F5
Constantin,
I resolved the issue by using dynamic linking  for my dll with windows API instead of static by adding the .lib to the project. This is a bit strange...
Stan
Message 41 of 49
(3,210 Views)
It's been a while since my debugger crashed.  But it did just now and I finally got a chance to run your application.  I got no windows in red:
Message 42 of 49
(3,157 Views)
Hello Electro,
Your windows seem to be from LabWindows/CVI. You should enter the process ID of your program (the one you are debugging with CVI).
Since you said WebBrowser.prj doesn't have the problem for you, the cause of the hang could be different in your case but it's worth a try.
Constantin
Message 43 of 49
(3,154 Views)
Ah, of course.  My mistake.
While I wait for another crash, I've been seeing these dialogs (one after the other) frequently when starting the debugger:
Are these related to this discussion or not?  For what it's worth my Execution Profiler output looks pretty good in terms of process load:
2015-03-04 14_53_38-execution profiler.cvip - XRF_Burn-In DEBUG.exe, pid = 7368.png
Message 44 of 49
(3,140 Views)
Do you use the output queue with your com ports? If so and can disable it, set the output queue length to -1 in opencomconfig...
Message 45 of 49
(3,137 Views)
Mine is already set to -1 (immediate write).
Message 46 of 49
(3,135 Views)
Hello Electrolund,
These dialogs are normal to appear after you kill the debugger. Because you manually killed it, CVI is in a bad state.
Do you see the dialogs after you restart CVI?
Message 47 of 49
(3,121 Views)
I think you're right.  After a restart, I don't think I see those anymore.  I'll pay more attention next time.
Message 48 of 49
(3,111 Views)
Hello all,
The issue should be fixed in LabWindows/CVI 2015 f1 patch.
Have a nice day,
Constantin
Message 49 of 49
(1,950 Views)
