LabWindows/CVI
DataSocket event on RT engine
Hi
Am using DataSocket to communicate between 2 applications, one of the application will be running on the RT PXI, and other on a normal PC. Presently I have created a while(1) loop in labview with DSread function in it to check arrival of latest data, this would not be very efficient, is it possible in any way that I can trigger event on change of data, in DataSocket item, As far as I know event structure can be used only for UI control's and that will not be used in RT. kindly give any suggestion
Arun
(3,273 Views)
Looks like you're using LabVIEW. Try posting on the LabVIEW or the RT forum.
Message Edited by bilalD on 04-06-2005 09:19 AM
Bilal Durrani
NI
(3,269 Views)
