LabWindows/CVI
DDraw
Hi there,
Does the panel created from NewPanel() or from User Interface Editor supports DDraw surface and access the underlay of an image buffer?
If not, does any other controls support?
I have been trying to solve by problem and the above are 2 areas I was told to into.
Thanks in advance.
william
(3,141 Views)
I assume by DDraw you mean DirectDraw from DirectX. CVI doesn't have DirectX drawing support functions. I would recommend you look at using the canvas control. The canvas control is a general drawing area where lines, shapes and bitmaps can be drawn.
Look at the example \cvi\samples\userint\canvas.prj for an example of using the canvas control.
Best Regards,
Chris Matthews
(3,141 Views)
