LabWindows/CVI
DDE server error
hello there
whenever i run a program there is this error popping up
Fatal error opening databse
The database path name is invalid or longer than 38 characters (error #24)
anyone knows to fix this issue
thank you so much
(2,331 Views)
Hello, please do not repeat your question over and over in a short period of time: opening several threads and reviving very old discussions won't give you more visibility!
Regarding your question, we are not magician to know what your code looks like: if you receive an error on a specific segment of program, posting the related code will help others to understand what's happening. Specifically, if the error regards the 'database pathname' without knowning it and the function on error we cannot say anything reasonable.
(2,314 Views)
