LabWindows/CVI
DBExecutePreparedSQL - documentation bug
I think that documentation for DBExecutePreparedSQL function contains a bug.
The description for return value resultCode states:
Statement execution handle that identifies the statement and is a parameter to other functions. If the return value is less than or equal to 0, the LabWindows/CVI SQL Toolkit was not able to execute the statement.
but it doesn't seem a statement execution handle.
The main difference is that 0 is returned if everything works fine.
Could you verify (and hopefully fix it), please?
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,548 Views)
Accepted by topic author vix
Thanks for pointing that out. CAR #695026 has been written.
Catalin
(3,522 Views)
I can confirm that return = 0 everything works fine, thanks vix, you solved a big headache for me!
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
(2,181 Views)
