LabWindows/CVI
DAXmx Documentation
I have compiled and linked the sample program Output-8255withDelays.c. However, there are two functions in the example that are not in the DAQmx documentation, DAQmxSetHshkDelayAfterXfer() and DAQmxSetExportedHshkEventInterlockedDeassertDelay(). The version of DAQmx is 8.0 for Win2K/XP.
Where is the documentation for these functions?
(3,231 Views)
Charles,
I have DAQmx 8.1 installed, so that could account for the discrepancy, Here is what my NI-DAQmx C Reference Help lists as the description for these functions:
DAQmxSetHshkDelayAfterXfer - Specifies the number of seconds to wait after a handshake cycle before starting a new handshake cycle.
int32 __CFUNC DAQmxGetHshkDelayAfterXfer(TaskHandle taskHandle, float64 *data);
int32 __CFUNC DAQmxSetHshkDelayAfterXfer(TaskHandle taskHandle, float64 data);
int32 __CFUNC DAQmxResetHshkDelayAfterXfer(TaskHandle taskHandle);
DAQmxSetExportedHshkEventInterlockedDeassertDelay - Specifies in seconds the amount of time to wait after the Handshake Trigger asserts before deasserting the Handshake Event if Output Behavior is DAQmx_Val_Interlocked.
int32 __CFUNC DAQmxGetExportedHshkEventInterlockedDeassertDelay(TaskHandle taskHandle, float64 *data);
int32 __CFUNC DAQmxSetExportedHshkEventInterlockedDeassertDelay(TaskHandle taskHandle, float64 data);
int32 __CFUNC DAQmxResetExportedHshkEventInterlockedDeassertDelay(TaskHandle taskHandle);
Hope this helps,
Ryan Verret
Product Marketing Engineer
Signal Generators
(3,201 Views)
