LabWindows/CVI
DAQmx get task status
I would like to get info if the particular task was already started.
I have functions
CreateTask
CreateWave
StartTask
They should be started in this order at 1st time. Afterwards I can call CreateWave to generate new waveform without calling function StartTask.
Problem: I don't know how to check if user started task already so i'm always stoping and starting task before i call CreateWave and that is a time wasting.
You can see part of my code bellow.
Thanks Michal
int CVICALLBACK CreateTask (int panel, int control, int event,
void *callbackData, int eventData1, int eventData2)
int32 error=0;
float64 freq=0;
char errBuff[2048]={'\0'};
freq=1000000; //1000Hz
switch (event)
case EVENT_COMMIT:
// DAQmx Configure Code
DAQmxCreateTask("",&taskHandle);
DAQmxCreateAOVoltageChan(taskHandle,"Dev4/ao0","",-10.0,10.0,DAQmx_Val_Volts,NULL);
DAQmxCfgSampClkTiming(taskHandle,"",freq,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000);
break;
return 0;
int CVICALLBACK StartTask (int panel, int control, int event,
switch (event)
case EVENT_COMMIT:
DAQmxStartTask(taskHandle);
break;
return 0;
int CreateWave(float64 data[])
DAQmxErrChk (DAQmxWriteAnalogF64(taskHandle,1000,0,10.0,DAQmx_Val_GroupByChannel,data,NULL,NULL));
return 0;
(4,400 Views)
I think i found the answear.
DAQmxIsTaskDone (taskHandle, &isTaskDone);
returns me always 1 if the task is not running and 0 if is running.
(4,399 Views)
Hello Michal,
For future inquiries, the NI-DAQmx C Reference Help can be very useful. More information about the NI-DAQmx documentation can be found here.
Matt Anderson
Hardware Services Marketing Manager
(4,374 Views)
