LabWindows/CVI
DAQMxReadAnalogF64
Hello
I have some problem with data acquisition...
I would say that it is incredible or I am becoming mad :
 here is my code:
int main (int argc, char *argv[])
status = CmtNewTSQ (QUEUE_SIZE, sizeof (double),OPT_TSQ_AUTO_FLUSH_EXACT, &queue);
// create new pools that will hold threads.
    CmtNewThreadPool (1, &poolpublish); // one to publish data after
 CmtNewThreadPool(1, &poolpid); // after for a PID loop
// install a callback function that will launch notify when there are new items in queue
 CmtInstallTSQCallback (queue, EVENT_TSQ_ITEMS_IN_QUEUE, 100, Notify,NULL, poolpublish, &callbackId);
// Lock creation to protect threads (no interation between them)
 CmtNewLock (NULL, 0, &mylock);...
  status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDWTX,1);
    status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDWTY,1);
                      //strong trap X and Y
 status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDSTX,1);
    status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDSTY,1);
         //weak trap sumX and sumY
    status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDWTSUMX,1);
    status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDWTSUMY,1);
                      //strong trap sumX and sumY
 status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDSTSUMX,1);
    status = NIDAQmx_NewPhysChanAICtrl(tabpanelHandlepos,TABPANEL_ChANPSDSTSUMY,1);
I ave a callback for data acquisition:
int CVICALLBACK AcquireData (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
if (event == EVENT_COMMIT)
status= DAQmxCreateTask ("TaskVoltageInputPSD", &TaskVoltageInput);
    taskCreated = 1;
     //WEAK TRAP PSD reading position :
         /* channel 0 input X weak trap*/
         status= DAQmxCreateAIVoltageChan (TaskVoltageInput, "Dev1/ai0", "InputVoltWKX",
          DAQmx_Val_Cfg_Default, -5.0, 5.0,
          DAQmx_Val_Volts, "");
       /* channel 1 input Y weak trap*/
        status=  DAQmxCreateAIVoltageChan (TaskVoltageInput, "Dev1/ai1", "InputVoltWKY",
    //STRONG TRAP PSD reading position  :
      /* channel 2 input X strong trap*/
          DAQmxCreateAIVoltageChan (TaskVoltageInput, "Dev1/ai2", "InputVoltSTX",
      /* channel 3 input Y strong trap*/
        DAQmxCreateAIVoltageChan (TaskVoltageInput, "Dev1/ai3", "InputVoltSTY",
          .....there are other channels made on the same scheme
// the clock
status = DAQmxCfgSampClkTiming (TaskVoltageInput, "OnboardClock", SAMPLING_RATE,
        DAQmx_Val_Rising, DAQmx_Val_ContSamps, SAMPLING_RATE);
//  start the task
   status= DAQmxStartTask (TaskVoltageInput);
 // launch the publish thread :
status= CmtScheduleThreadPoolFunction (poolpublish,Publish,NULL, &thread);
while (stop ==0)
    /* find out how many samples are available and read them */
    status= DAQmxGetReadAttribute (TaskVoltageInput, DAQmx_Read_AvailSampPerChan,&data.daq);
 // read data and put them in the matrix data.values , data are grouped by channels
    status = DAQmxReadAnalogF64 (TaskVoltageInput, DAQmx_Val_Auto, 1,DAQmx_Val_GroupByChannel, data.values, NUM_VALUES, &data.count, NULL);
    /* write the data to the queue if successful */
 // lock this thread to avoid interferences
  CmtGetLock (mylock);
  status =CmtWriteTSQData (queue, &data, NUM_VALUES*nbchan, 0, NULL);
  CmtReleaseLock (mylock);
  // for the end of the other thread
   ProcessSystemEvents ();
   // stop and clear the task
  DAQmxStopTask (TaskVoltageInput);
        DAQmxClearTask (TaskVoltageInput);
Then in publish, there are different plotstripchart function and plotpoint..... But i am using the same functions in the same order as the one in the example :Cont Acq-Int Clk that is in the folder samples , DAQ mx, Input volatge
And these example manage to acquire data.....
Please help
estelle
(3,475 Views)
Hi Estelle,
What kind of issue are you seeing with this code? Does it throw an error on execution (in which case an error code would be very helpful) or does it just not output as expected? I see that our examples work for you so it sounds like your DAQ card is up and running, but its very hard to trouble shoot from code alone. Which DAQ card are you using and which version of CVI?
Andrew S.
(3,447 Views)
