LabWindows/CVI
Creating Task for USB-6008 using LabWindows CVI
I want to use NI USB-6008 with Lab Windows CVI. I have NI DAQmx 7.5 installed on my PC.
Using LabView I could access USB-6008 and could do data acquisition.
But I could not create Task for USB-6008 in LabWindows. In Lab Windows the equipment is not
getting identified. It is giving as no Physical equipment is connected.
Do you I need do anything more to work with USB-6008 from LabWindows?
Ravisankar
(3,846 Views)
I have the same behaviour here with a USB-6009 😞
However using another approach i did get some data back from ADC namely using a driver called Ni DAQ Base MX which are also installed in the NI DAQ installation.
Using the sample programs i managed to get data from the device, but it should also be possible using the DAQ library functions, did you suceed later ?
If so i would like to know how ?
B.Rgds.
Peter PBI
Denmark
(3,828 Views)
Hi
I could create task for USB-6008 from labwindows after switching to new driver.
The link below gave me hint for this. You can also try this.
Ravi
HYDERABAD
INDIA
(3,823 Views)
Hi again,
Thank you very much Smiley Very Happy
Just tried switching driver and now there are more life, i will exmaine this more next week.
Have a nice weekend ;o)
Peter
PBI-Dansensor A/S
(3,819 Views)
