‎03-04-2008 02:20 PM
Robert,
Add this statement to the code and see if it works, this contains the location. Obviously MyDir and MyDatabase.mdb should fit to your parameters.
RegWriteString (REGKEY_HKLM,
DatabaseKey,
"DBQ", //The Location,
"C:\\MyDir\\MyDatabase.mdb"); //location of the database on the machine
-Dave
‎03-04-2008 03:28 PM
I would try it tomorrow to see how it works.
Robert
‎04-17-2009 12:58 PM
For me, the easiest has been to create a myconnection.dsn file using the ODBC administrator control panel.
Then, in your executable distribution, include the myconnection.dsn file, and stick it in C:\Program Files\Common Files\ODBC\Data Sources
Then, you can use the following connect string : "filedsn= myconnection.dsn;UID=userid;PWD=password", and it works like a charm, both in LabVIEW and LabWIndows
in addition, because the DSN is in a standard location, other application, such as Excel can use it just as easy.
