LabWindows/CVI
Create Distribution Kit... File Size - CVI 7.1
Using LabWindows CVI 6.0, the distribution kit for an one of our applications totaled about 4 Megabytes. Using LabWindows CVI 7.1 the distribution kit for the same application totaled about 15 Megabytes!! The full CVI run-time engine was included in both cases.
Is this expected behavior with CVI 7.1? If not, any initial thoughts on what is going on?
David Clark
(3,353 Views)
Shortly after I posted that last message I found the problem.
The setting "Install DataSocket Support" was set to "Always."
It seems that if you open a CVI 6.0 project in CVI 7.1 that this setting defaults to "Always." Unfortunatley I unistalled 6.0 so I can't go back and look at the setting in that version. The install is now back to a reasonable size.
David Clark
(3,348 Views)
Seems in CVI 6.0, the setting is "If Needed" by default. I tried opening the CVI 6.0 project in 7.1 and it was set to "If Needed" as well.
It might have been a setting specific to your project. If you do run into issues like this again, feel free to post here.
Hope this helps
Bilal Durrani
NI
(3,340 Views)
