LabWindows/CVI
Create Colour Scheme tabstrip
someone have idea to create colour scheme tabstrip like picture below.
(3,283 Views)
If you are not too worried about speed, you could use a Canvas, with CanvasDrawLine() in a loop. Use the loop variable to set the line start/end points and the colour (using ATTR_PEN_COLOR) to draw a short line in a slightly different position at each iteration.
JR
(3,271 Views)
in vb program i also use draw line method. Cause not so familiar with NI, need so time to handle. btw thank you for ur reply. i will try it.
(3,260 Views)
