The VS 2005 project wizards were added in version 8.0.1 of CVI, so you won't find them unless you have that version or higher. If you do have the wizards, they will be accessible from the new project menu item. You should see a LabWindows/CVI project grouping that has the conversion wizard you are looking for.
If you have CVI 8.0.1 and you still don't see these items, you may not have them installed. By default, the wizards are installed if you installed CVI
after VS 2005. If you installed them in the other order, the VS 2005 wizards feature is turned off by default in the installer. If this is the case, you would need to go to Add/Remove Programs and choose to modify your installation of CVI. This allows you to select the VS 2005 wizards for installation.
Hope this helps.
Mert A.
