LabWindows/CVI
Converting A Double To A String
In LabWindows CVI, is there a way to convert a double data type into a string?
(5,035 Views)
You can do something like this.
double number;
char string[256];
sprintf(string, "%f", number);
Sheetal
Thanks.
CVI 2010
LabVIEW 2011 SP1
Vision Builder AI 2011 SP1
(5,032 Views)
Thanks Sheetal. I'll give that a try.
(5,023 Views)
You can use sprintf, but the limitation of this function is that you will need to know how long your double is:
double num;
char str[length of double];
sprintf(str, "%2f", num);
If you want to convert an array of doubles to an array of characters, you could also use the function ConvertArrayType() in the Programmer's Toolbox.
Thanks.
Wendy L
LabWindows/CVI Developer Newsletter
(5,020 Views)
What I was converting isn't an array of doubles. It is just a plain double data type. So I'm not too sure if the ConvertArrayType()function would work in this case. Thank you anyway for your response. I appreciate the help.
(5,013 Views)
