LabWindows/CVI
Control callback error during compile in debug mode using CVI 9.0
We recently upgraded to CVI 9.0 and I am now having some problems with one
of my projects.  It will not compile in debug mode.  If I compile in debug
mode I always get "A custom control callback raised an exception" and sometimes
see "Unrecoverable Internal Error at 001B:102992CA" along with the custom
control error.   The dll's never get created.
Everything works fine in release mode with CVI 9 and when I use CVI 8
(release or debug mode).
I have reproduced the compile issue using CVI 9 (9.0.1 RTE) on two different PC's.
One was running windows XP SP2, the other SP3.
I have attempted to rebuild the project from scratch, delete the cvi.build
directory, rebuild all .UIR's with no success.
I am attempting to isolate the code to a minimum in order to reproduce the
issue for posting but it seems the problem disappears by eliminating
arbitrary and unrelated code that has no logical pattern that would point
to a possible solution.  If I set the build option debugging level to
no run-time checking, the entire project will compile in debug mode.
Has anyone seen this type of thing before or would have a suggestion of something
to try?
Thanks in advance.
(4,276 Views)
kliche,
I am not using CVI 9 yet but I have read some similar questions recently on this forum: while waiting for some more experienced people to help you, you could take a look at this thread and see if some of the suggestions listed applies to your situation.
(4,262 Views)
Do you have version 9.0 or 9.0.1? You can see this in the lower right corner of the splash screen that comes up at startup (or Help>>About LabWindows/CVI). There was a known crash fixed between 9.0 and 9.0.1 that was related to initializing large character arrays with small strings (e.g. char x[50000] = "").
Mert A.
(4,259 Views)
I have 9.0.0 (348).  Is there a 9.0.1 downloadable update immediately available?
(4,254 Views)
If you have SSP, you can go to www.ni.com/src and download the update from there.
Mert A.
(4,249 Views)
Looks like 9.0.1 has fixed the compile problem.
Thanks!
(4,219 Views)
