LabWindows/CVI
Context menu
Hi to all and thanks in advance.
My question is very simple:
how can i implement a context menu using LabWindows/CVI?
Thanks a lot...
LOCK.
(3,905 Views)
In response to an EVENT_RIGHT_CLICK, call the function RunPopupMenu.
Luis Gomes
NI
(3,905 Views)
Thanks a lot Luis, RunPopupMenu works...
But now i have another problem...
RunPopupMenu ever displays the menubar at the top of the window.
Can i avoid this in some way?
Thanks a lot..
LOCK.
(3,905 Views)
It shouldn't display the menubar, unless you also associate the menubar with the panel.
Look at the smithdem example, in samples\apps\smithchart\smithdem.prj. It uses RunPopupMenu when you left-click or right-click on the chart. Do you use it the same way?
- luis
(3,905 Views)
All is clear now.
Thanks a lot, Luis...
LOCK.
(3,905 Views)
