LabWindows/CVI
Connection check for the NI USB-6008
I'm using the NI USB-6008. I want put, into my software, a connection check: I want a message box in event of missing connection.
I tried the following instructions:
int variable;
variable = DAQmxLoadTask ("MyVoltageOutTask", &th_analog_write_AO0);
if (variable!=0)
         MessagePopup ("Attention!!!", "Hardware did not find");
The function DAQmxLoadTask returns "0" only in event of success, but the compiler gives me error.
The compiler say:
        Device cannot be accessed
and the error is at "variable = DAQmxLoadTask ("MyVoltageOutTask", &th_analog_write_AO0);"
Can you help me please?
Thank you!!!
Stefano
(3,244 Views)
Hello Stefano,
in order to verify the correct connection for your DAQ board, I suggest you to use the following functions:
  1. DAQmxGetSystemInfoAttribute (DAQmx_Sys_DevNames): this attribute allows you to get the list of the devices currently installed on your PC;
  2. Once you get the device list, you can perform a reset of each device by using the function DAQmxResetDevice();
You can take a look on the function help for both of them in order to get more informations.
Hope this helps,
Fabio
Fabio M.
NI
Principal Engineer
(3,202 Views)
Thank you! I solved my problem with your suggestion.
Thanks!
(3,182 Views)
