LabWindows/CVI
ConfigureLogging Timestamp TDMS
We are looking to streak DAQmx analog input data directly to disk using 'DAQmxConfigureLogging' function.  The data will be post-processed after the collection.   For time coorelation we plan on doing something like this:
// write time stamp
TDMS_CreateFileEx
TDMS_AddChannelGroup
TDMS_AddChannel   // allocate 'TDMS_Timestamp' channel
get CVI time
TDMS_AppendDataValues    // write CVI time to tdms file
TDMS_CloseFile
// start daqmx task
// configure daq task with the 'DAQmxConfigureLogging' function using TDMS file used in previous steps
// start daq task
Questions:
  1. Does this sound feasible?
  2. In regards to post-processing we need to output to customer-defined text file where every sample is scaled & timestamped.   Are there any examples that would be helpful in regards to this?
Thank you,
(3,510 Views)
It looks like you are on the right track. I would suggest looking into our example codes which do a similar task to what you describe here if you have not already. They are located at a location similar to the below path.
All Programs\National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Analog In\Measure Voltage...
I hope this helps,
Eric
(3,487 Views)
