LabWindows/CVI
Compiler environment variables
Hi all,
I'm trying to use the function implemented in
the .
The SDK help on that item saids that it suported only under
winnt4.0/2000 (so it fits my case).
BUT when I compile the module contaning this call it returns with the
error: "Missing prototype"!!! although I encluded the and
the as written in the SDK help.
note: The also located in that dll warks fine!
I've searched in the for the problematic function and foud
the following:
#if(_WIN32_WINNT >= 0x0400)
WINBASEAPI
BOOL
WINAPI
TryEnterCriticalSection(
IN OUT LPCRITICAL_SECTION lpCriticalSection
#endif /* _WIN32_WINNT >= 0x0400 */
It seems that the compil
er environment variables isn't set correctly
somehow.
[Image]
How can I change the Compiler environment variables to match my needs?
Thanks...
(3,426 Views)
The Options menu in the Project Window has an entry for Compiler
Defines. Try adding this: /D_WIN32_WINNT=0x0400
Peter
(3,426 Views)
