LabWindows/CVI
Compilation failed without errors
I'm french so, sorry for my bad english.
I have a problem with my 2013 CVI...
When i try to compile a simple project (1 file .c whit a simple main function), my build output displays only the 2 lines:
Build Status (test.prj - Debug)
Build failed.
The selected compiler in Build Options is Standard CVI Compiler...
I checked all Build Options and i found nothing wrong...
Please i need help....!Smiley Sad
Thanks a lot
Message 1 of 11
(7,299 Views)
Check in Options» Build Options which warning level you have set and also that Show warning flags in Build Output Window option is selected.
A list of all warnings the compiler can raise depending on the warning level can be found here
Message 2 of 11
(7,270 Views)
Thanks for your answer.
I already checked warning level and it was on Standard.
I tried to set it to Extended but it did not solved my problem...
The option Show warning flags in Build Output Window was already checked.
So my problem is still here... Smiley Sad
Message 3 of 11
(7,266 Views)
Is your project located on a network drive? If yes, this is a known issue for CVI 2013, see this post.
If this is the case, the problem should be resolved by installing LabWindows™/CVI™ 2013 f1 Patch.
Message 4 of 11
(7,261 Views)
Hi Solaris,
I don't know what may be happening but some information more can give somebody the right clue to suggest you a sokution: which OS are you using.?  Is it 32 or 64 bit?
Are you using some special library in your project? Which configuration are you trying to compile your project with (release Vs. Debug,  32 Vs.  64 bit)?
And finally,  does this happen also if you try to compile one of the example project cvi comes with?
Message 5 of 11
(7,259 Views)
Searching the forum I found that this also can be caused by some extended characters in the project path(e.g. é).
See this post. I hope it helps
Message 6 of 11
(7,258 Views)
Thanks a lot for your answer
But my project, and the target are all on local drives....
Message 7 of 11
(7,257 Views)
Yes, sorry i give you some details:
- I am on Windows7 64bit,
- My project is the most simple as possible : 1 file .c with :
int main (int argc, char **argv)
  return 1;
- It contains no lib.
- I tried to compile all the possible configuration (Release/Debug 32 / 64 bit) and the problem is on the 4 configurations
Message 8 of 11
(7,253 Views)
Thanks Constantin,
But in the path, i've no special character,  nor spaces or anything else...
Just D:/TEMP/test.prj...
Message 9 of 11
(7,252 Views)
Does the error happen also with the sample projects shipped with CVI(c:\Users\Public\Documents\National Instruments\CVI2013\samples)?
Can you post your siple poject for analysis
Message 10 of 11
(7,246 Views)
