LabWindows/CVI
ComWrite in labwindows
I am facing problem in writing hex data to com port using ComWrite.  How i will make sure that whatever data sent is written to my target properly because i am not seeing any changes in my target.
Whenever i am trying to read data from my target which is continously sending some response i can read through comRead successfully but write doesnt goes well. I cross verified the same message with other termnial where i can write hex data. but in CVI i cant. your feedbacks are much appreciated.
int no_of_bytes=0;
char comdata[100] = {0x28,0x00,0x02,0x00,0x01,0x00,0x01,0x00,0x00,0x00,0x29};
no_of_bytes = ComWrt (COM_PORT, comdata, strlen(comdata));
thanks.
(4,822 Views)
The proble is in the use of strlen () to calculate the number of bytes to send: strlen treats c-like strings, that is it will return the position of the first NUL bite in the string: in your case it will return 2 bytes instead of 11 you are expecting.
The only solution is to calculate this number in a different way.
(4,821 Views)
Thank u very much.
now i have written my code as
no_of_bytes = ComWrt (COM_PORT, comdata, 11);  and it works.
instead of couting the number of bytes manually is there any way where we can get count of number of bytes?
(4,814 Views)
Accepted by topic author ammukrish
Since you are dealing with raw data, there is no way to discriminate the number of bytes to send: each byte could theretically assume ever value fro 0x00 to 0xFF.
Unless your protocol has some characteristics you can leverage on (e.g. some end-of-transmission character or 7-byte protocol) I see no way other than counting bytes while you are preparing the message to send.
(4,812 Views)
