LabWindows/CVI
Code is Crashing with FATAL RUN-TIME ERROR: General Protection Fault
I already checked that. Please check the RunSeqChangePreTest function definition in previous comment.
In that GPF is generated after full execution of testResult = TX_RunPrePostTest(&dataRec, &errorRec, TRUE, TRUE);
 Couldnt find any faults in TX_RunPrePostTest while debugging. Once it finishes execution of this function, program crashes with GPF
Message 21 of 26
(1,175 Views)
Hi
Anyone has solution for the GPF issue?
Message 22 of 26
(1,156 Views)
Not really. GPF errors can be caused by many things. It always involves some bad programming, but to find out which bad programming is an art of debugging, which is a fundamental element of code programming.
Rolf Kalbermatter  My Blog
Message 23 of 26
(1,151 Views)
I tried to debug the code. But issue is it is generating just after the function execution.
All lines of that function executes without any issue. But then from out of nowhere this fault generates
Message 24 of 26
(1,146 Views)
That would point at some form of stack corruption. But I can't see from the code any glaring issues. It's tempting to put the blame on the used libraries but in my own experience it is almost always my own code which does this.
Message 25 of 26
(1,140 Views)
Using cvi 5.1 and compiled under release and debug, each one separated *.exe file run well no errors
But when i try to run debug from IDE, the program crash with
NON FATAL RUN-TIME ERROR: General Protection Fault
So i can´t debug my code
Message 26 of 26
(362 Views)
