LabWindows/CVI
Code buider - Generate Control Callback is disabled
Can any one say, Why Generate Control Callback is disabled ?
Thank you
AD
Adarsh
CLA - Certified LabVIEW
Architect
https://www.youracclaim.com/badges/4871da75-1b8b-422a-a881-9ab206d2d36d/public_url
(4,926 Views)
Normally it happens when you have not specified a callback for the control:
(4,922 Views)
all I can add is that the entry 'Generate Control Callback' is dimmed if more than one control has been selected. Sometimes this happens by accident...
(4,921 Views)
I have selected default events. EVENT_COMMIT, EVENT_RIGHT_CLICK
Adarsh
Architect
(4,915 Views)
Accepted by topic author Adarsh
This is done in Code >> Preferences >> Default Events... menu function, but the editor does not automatically create control callbacks: you must manually set the callback for each and only the controls you want a function assigned to; this is done in the properties panels for each control.
(4,912 Views)
