LabWindows/CVI
Check Box in a Table
Is it possible to place a check box into a cell within a table control?
(8,847 Views)
Yes, sort of. Make the cell a picture cell (ATTR_CELL_TYPE = VAL_CELL_PICTURE) and then give it an image that looks like a checkbox (you can obtain one by calling GetCtrlDisplayBitmap on a checkbox control).
You will then need to toggle the 'on' and 'off' images whenever you receive a left click event on the cell.
Luis
NI
(8,847 Views)
Could I get an example on this? I could not find/get the check box picture in the table by the callback listed in the reply.
ChipB
(8,545 Views)
ChipB, if you are using latest cvi versions you can benefit from new cell types that were introduced in version 8, specifically ring cell type: as an alternative to a checkbox you could create two items labelled Yes and No in a ring cell. in the table callback you will retrieve the cell value on a COMMIT event as a string and discriminate on it.
Regarding Luis suggestion, you must have a checkbox elsewere in the panel, retrieve its bitmap with GetCtrlBitmap (panel, control, 0, &bitmap); (well, two bitmaps, corresponding to checked / unchecked values; the bitmap can next be discarded) and load one of them as an image in a table cell of picture type: in the callback for table you will need to update the cell picture depending on previously loaded one. Consider that a cell can hold values for different types regardless the type shown: you can show a picture in a cell but contemporarily hold a integer value 0 or 1 corresponding to the "checkbox" value shown. in the callback function you can manipulate both the picture and the value associated to the cell.
(8,525 Views)
Here is a simple program that shows how to easily put a check box in a table cell.
http://forums.ni.com/ni/board/message?board.id=180&message.id=13287#M13287
(8,512 Views)
Ok, I got the check box to change state... but getting a 1 or 0 returned escapes me... I have a table of measurements and the checked measurements I want to put into an array to do a linear extrapolation on... but when I roll through the row 1 column(count) to find the "checked" items, I don't get a returned value. what is the reason? same program used just build a on/off array
ChipB
(8,257 Views)
In the tableCheck example program (from the link in my previous post), check out the function ToggleTableCellCheck. It is storing the 1 or 0 (or whether the checkbox is checked or not) in the numeric value of the table cell. You could make a function like this to return the check state of a table cell.
/* returns 1 if the cell is checked, 0 if the cell is unchecked */
int GetCellCheckedState(int panel, int table, Point cell)
 int val;
 SetTableCellAttribute(panel, table, cell, ATTR_CELL_TYPE, VAL_CELL_NUMERIC);
 GetTableCellVal(panel, table, cell, &val);
 SetTableCellAttribute(panel, table, cell, ATTR_CELL_TYPE, VAL_CELL_PICTURE);
 return val;
I hope this helps.
- jared
(8,231 Views)
