LabWindows/CVI
Changing the axis crossing points in an excel chart
How to I change where the axis crosses in excel.  I am plotting data that goes from a negative number to a positve number and by default the chart wizard always has the axis cross at zero.  In excel you can set where the axis crosses by setting the "Value (Y) axis crosses at:" field to whatever you want.  For example I want to make the Y axis cross the X axis at -3000.
Message 1 of 1
(3,491 Views)
