LabWindows/CVI
Cannot grab from cam1
I use logitech webcam plug in to usb it show in Measurement & Automation as cam1
when i change cam0 to cam1 it show error massage like the picture.
how can i use cam1
// Author : Vision Assistant
// Purpose: This file implements the algorithm prototyped in Vision Assistant.
// WARNING: This file was automatically generated.
//          Any changes you make to this file will be lost if you generate the
//          file again.
//     Includes
#include <stdio.h>
#include <nivision.h>
#include <NIIMAQdx.h>
#include "ImageProcessing.h"
//  Defines
#define DISPLAY_WINDOW 0
//  Main Function
int main (int argc, char *argv[])
    int success = 1,g=2;
    int err = 0;
    SESSION_ID sid;
    unsigned long bytePerPixel;
    ImageType imageType;
    Image* image;
    // IMAQ Vision creates windows in a separate thread
    imaqSetWindowThreadPolicy (IMAQ_SEPARATE_THREAD);
    // Open a session
    IMAQdxOpenCamera ("cam0", IMAQdxCameraControlModeController, &sid);
 IMAQdxConfigureGrab (sid);
  printf ("capture.\n");
    getchar();
    // Create an IMAQ Vision image
    image = imaqCreateImage(IMAQ_IMAGE_U8, 0);
 while(g>0)
    // Acquires an image.
   IMAQdxGrab (sid, image,TRUE, 0);
    // Vision Assistant Algorithm
    success = IVA_ProcessImage(image);
    if (!success)
        err = imaqGetLastError();
    // Display the image
    imaqMoveWindow(DISPLAY_WINDOW, imaqMakePoint(0,0));
    imaqSetWindowPalette(DISPLAY_WINDOW, IMAQ_PALETTE_BINARY, NULL, 0);
    imaqDisplayImage(image, DISPLAY_WINDOW, TRUE);
    // Wait for a key press before exiting
    printf ("Press Enter to exit.\n");
    getchar();
    // Dispose resources
    imaqDispose(image);
    // Close the the session
 IMAQdxCloseCamera(sid);
    return 0;
(3,603 Views)
Hi Unwell,
This error appears to stem from a program that uses a kernel debugger like WinIce for Windows NT Users.  Nero Burning Rom 6 (or higher) is one software that is considered by Windows as a kernel debugger. Also other software like anti-virus, intrusion prevention software, some CD/DVD/Blue-ray burning software can cause this as well.
Just out of cursoity what version of Windows are you running?
Joe Daily
may the G be with you ....
(3,563 Views)
win 7
(3,539 Views)
hi unwell,
Does the webcam work in MAX? Have you tried rerunning Vision Assistant, selecting cam1 in the process. What version of NI-IMAQdx do you have installed?
Joe Daily
(3,509 Views)
