LabWindows/CVI
Cannot change control
I have a binary control in a UIR. I'm able to change it's value
(position) in the uir edit window without any problem.
When I run the project, I cannot change the switch position anymore
with my mouse.
I checked evrything and cannot see any problems. I've never seen this
before.
(Win 98 CVI 5.0)
Any hints?
Urs
(3,678 Views)
Some possible reasons :
- The control-mode is set to 'indicator'
- You didn't call RunUserInterface()
- You did call RunUserInterface(), but then you started a loop out of an
event, and forgot to call ProcessSystemEvents() within the loop.
Check this and tell us, if you succeeded or if you need more information !
Manfred
urs schrieb in im Newsbeitrag:
e5cb2278.0108130121.e34e6ef@posting.google.com...
> Hi,
> with my mouse.
> before.
> (Win 98 CVI 5.0)
> Any hin
ts?
> Thanks
> Urs
(3,678 Views)
Thanks for the hints, Manfred
The Switch is on control mode 'hot'.
The application is running and I'm able to change all the other cotnrols on
the same panel.
So there must be another problem ?!
Urs
> Regards,
> Manfred
> > Hi,
> > (po
> > with my mouse.
> > before.
> > (Win 98 CVI 5.0)
> > Any hints?
> > Thanks
> > Urs
(3,678 Views)
If you like, you can send me a piece of code and the .uir, to take a look on
it !
Manfred
aritron schrieb in im Newsbeitrag:
3B78C5FB.6A0B9CA@my-dejay.com...
on
> the same panel.
> Urs
> > Regards,
> > Manfred
> > > Hi,
> > > with my mouse.
> > > before.
> > > (Win 98 CVI 5.0)
> > > Any hints?
> > > Thanks
> > > Urs
(3,678 Views)
