LabWindows/CVI
Can not remove "Check Marks" for Read Only Projects Directory
I can not remove "Check Marks" for Read Only Projects Directory  as instructed on page 5 of Starting CVI ??? I am running Windows XP.
No matter which buttons I check or uncheck,hitting Apply or OK... NONE of the options, saves the Project File with the Read Only, permanently unchecked...
The instruction book says to remove ALL read only, by slecting all,going to properties and deselecting read only... as if ALL read only will be removed
NOT HAPPENING for ME ...
thanks. Abendicum
(2,781 Views)
Problem solved... Down loaded Windows XP drivers for 8.1 and all seems to be OK...
Ab
(2,769 Views)
