LabWindows/CVI
Can i use matrix functions with fmod
Hi There
This is my first post.-
 I need to use matrix function with the fmod() fuction in LabWindows.
Currently i have
time_ref_ch[p]=fmod((angle_red[number_of_probes_active] + angle_of_keyphasor[number_of_probes_active]), (360/number_of_blades));
That but it keeps on displaying 'operators of = have illegal types 'pointer to array 201' of long double and double
and also
Lvalue Required -----> have no idea what this is
. I have tried everything but i can get past it.
 Please help me out
(3,337 Views)
Can you post your definitions of the identifiers used? It might help to see what's going wrong.
JR
(3,327 Views)
Definitions are
long double time_ref_ch[number_of_probes_active][max_nmb_blades]
double angle_red[number_of_probes_active]
long double angle_of_keyphasor[number_of_probes_active]
#define max_nmb_blades 201
int number_of_blades=1
(3,312 Views)
You need an additional de-reference of your time_ref_ch variable. Defined as it is, the left hand side of your assignment (time_ref_ch[p]=) is still referring to an array, not an LValue. Something along the lines of: time_ref_ch[p][q]= (with appropriate values for p and q) will keep the compiler happy.
JR
(3,306 Views)
