LabWindows/CVI
Can I talk to a USB interface IOTECH data acquisition system with LabWindows CVI
(3,621 Views)
Hi cjp1,
I'm fairly certain this is possible, but I'd like to know what device you are using to get a better idea about your setup.  The device driver likely includes a c interface to the device, which you can use with CVI.  Once I have a bit more information on the device, I will be happy to provide more detail!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,593 Views)
I'm using a IOTech Personal Daq/3001 It's a USB 1-MHz Multifunction.
(3,496 Views)
Hi cjp1,
It looks like IOTech provides LabVIEW, c++, and VB6 support, not ansi C.  Since this is the case, you would need to create a c compatible dll using either LabVIEW or visual C++, then call this dll in CVI. For more information, see the links below:
Similar Forum Posts:
http://forums.ni.com/ni/board/message?board.id=180&message.id=29223&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=250&message.id=28239&requireLogin=False
Al B.
CTA/CLD
(3,476 Views)
