Hi Jeff,
Thanks for your reply.
Re-registering the same EveryNSamples event handler with the same task returns an error. Trust me, I tried it.
Had I been aware of the fact that passing NULL as the event handler pointer would unregister the event handler, I probably would have tried what you suggest. At this point, though, simply doing the loop is working perfectly for me. So, since it ain't broke, I see no reason to fix it.
Thanks once again.
Best Regards,
Matthew
