LabWindows/CVI
Can I execute a function immediately after RunUserInterface has been executed?
Using Labwindows 5.5.1:
I would like to execute a function immediately after loading a UIR panel and executing RunUserInterface.
One option is to use a timer control, set to a very short duration and have the callback function disable the timer control.
Is there a more elegant solution, say by queueing a call back event then calling RunUserInterface??
(3,350 Views)
In my opinion the use of PostDeferredCall () should answer your question. According to function on line help
"(PostDeferredCall) Posts a function to LabWindows/CVI that is to be called at the next occurrence of GetUserEvent(), RunUserInterface(), or ProcessSystemEvents()."
So it seems that the deferred function should be executed immediately after RunUserInterface is run.
Roberto
(3,350 Views)
Thanks Roberto,
PostDeferredCall() works fine
Alan
(3,350 Views)
