LabWindows/CVI
Calling Multiple mains
Darnell:
You made a reference earlier in this post about doing something "the book way".  What C reference book are you using?
Even with all the great references on the web, I still don't think they replace a good reference book.
If you tell me what book you're using, I will see if I can find a copy.  Then when future questions come up, I can point you to a specific reference in your book.
After I get a copy of your book, if I think it's weak on the basics, I may suggest another title.
Message 21 of 38
(2,190 Views)
C++  teach yourself  4th edition  Jesse liberty
Message 22 of 38
(2,184 Views)
1>c:\documents and settings\z1083774\desktop\jjjj\jjjj\edd.cpp(21) : error C2059: syntax error : ']'
he's getting this error now
#include <stdio.h>
long f_ConvDblToSingleArray ( double *double_array[][1000], double *single_array[3000] , int max_index );
int main()
int q=4,u=1000;
double *temp_data[][1000] ={0};
double *conv_data[5][1000] ={0};
double *meas[3000] ={0};
f_ConvDblToSingleArray( temp_data, meas, q );
f_ConvDblToSingleArray( conv_data, meas, q );
conv_data[q][u] = temp_data;//this gives me an error********************
return 0;
//Library Function...(This compiles...)
long f_ConvDblToSingleArray(double *double_array[][1000],double *single_array[3000] ,int max_index )
long error = 0;
int idx1 = 0;
int idx2 = 0;
int index = 0;
for (idx1=0; idx1 < max_index; idx1++)
for ( idx2=0; idx2 < max_index; idx2++ )
single_array[index++] = double_array[idx1][idx2];
return 0;
Message 23 of 38
(2,177 Views)
Darnell:
I told you earlier that you need to specify the number of rows in your array variable declaration.  Note the difference I specified between the array variable declaration (where you need to specify the number of rows) and the function parameter declaration (where you don't need to specify the number of rows).
Your statement
Should be
   double *temp_data[4][1000] ={0};
Also remember that I told you that what you are doing with the ={0} assignment is only setting the value of the first element in the array, not the entire array.
On to the line you flagged as an error.  That error message is not very helpful, but if you look at the data types of the two items in your assignment, you'll see what you are doing wrong.
conv_data[q][u] is a pointer to a double.
temp_data is a pointer to an array of pointers to doubles.
What are you trying to do?
Message 24 of 38
(2,174 Views)
im trying to take my time and look at it closely, alot of people are having this one issue for some reason. in C youcan do it, in C++ you cant.
i just tried in CVI and ran very fine, but  in c++ its not
Message 25 of 38
(2,172 Views)
now im getting just  one
error
1>c:\documents and settings\z1083774\desktop\jjjj\jjjj\edd.cpp(21) : error C2106: '=' : left operand must be l-value
int main()
int q=4,u=1000;
double temp_data[][1000] ={0};
double conv_data[][1000] ={0};
double meas[4000] ={0};
f_ConvDblToSingleArray( temp_data, meas, q ,u);
f_ConvDblToSingleArray( conv_data, meas, q ,u);
conv_data=temp_data;//this gives me an error
return 0;
Message 26 of 38
(2,174 Views)
Darnell:
For the third time, you need to specify the number of rows in your array variable declaration.
Don't say
Say
double temp_data[5][1000] ={0};  // 5 or however many rows you need
double conv_data[5][1000] ={0};
What are you trying to do with the statement
conv_data=temp_data; // ????
conv_data is already a pointer to an array with its value set.  Based on the way you declared it, you can't just move by trying to assign a new value to it.  That's why the error message said that the left operand must be an L-value.  An L-value is an entity that can accept an assignment (on the Left hand side of an assignment statment).  Based on the way you declared conv_data, the pointer value for that array is constant, can't be changed, and is not a valid L-value.  An L-value must have an address so something can be written to it.  conv_data does not have an address, it is an address.
What are you trying to do with that statement?
And another thing: you still haven't addressed Roberto's concern about the way you are using max_index in your loop.  You are treating the multi-dimensional array as if it's square, but it's not.
So are you using arrays of doubles or arrays of pointers to doubles?  You keep jumping back and forth every time you post some code.
You need to figure out what you are doing.
Message 27 of 38
(2,166 Views)
Darnell:
I didn't do a good job of keeping up with you changing back and forth between arrays of doubles and arrays of pointers to doubles.
I said
Your statement
Should be
But the assignment statement ={0} is wrong.  You are trying to assign an integer to a pointer to a double.
The statement should be
   double *temp_data[4][1000];
If you are using arrays of pointers.  Are you?
Message 28 of 38
(2,161 Views)
Al,
  I need to buy you a beer some time just for your effort and lack of homocidal actions.
Message 29 of 38
(2,158 Views)
scomack:
Thanks for the encouragement.  I guess it's a good thing that this forum is mostly anonymous.
Message 30 of 38
(2,154 Views)
