LabWindows/CVI
Callback function name/pointer difference?
It is possible with SetCtrlAttribute() to set the ATTR_CALLBACK_NAME and the ATTR_CALLBACK_FUNCTION_POINTER. Can I only specify one simultaneously, or do I have to specify them both? Which one do I use in which case?
The idea is that I have a function which builds a panel from scratch. The function which calls this function should specify the callback function of the to-be-made-controls of the panel. I'm a bit confused how to do this, with these 2 available options.
I'm making a periodic table of elements panel, and dependent on the program which uses it there should be different calculations made when an element-button is pressed. The easiest way is to let the calling program specify its own callback function.
CVI 6.0, btw.
Greetings,
Erwin Timmerman
(2,998 Views)
You can only set the value for ATTR_CALLBACK_FUNCTION_POINTER. ATTR_CALLBACK_NAME is not a settable attribute. See the function panel help for GetCtrlAttribute for more information.
I hope this helps
Bilal Durrani
NI
(2,988 Views)
