LabWindows/CVI
Callback Functions
How do I call a callback function from a regular function?
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
(4,477 Views)
Is it a callback for a user gui control? If so, then you might use the
automatic code generation to create a nearly-empty callback and then cut
'n paste the body of your regular function as needed.
B
ande at san dot rr dot com
(4,477 Views)
Thanks. I just starting doing that. Is there a way to programatically
cause and EVENT?
In article
the
cut
> B
(4,477 Views)
There is differents ways :
1) use CallCtrlCallback() : this function call directly the function
attached to a control
without giving time to the systeme to process the events....it's not really
a event.
2) Use PostDeferedCall() to call a function just after the return of the
current callback. This
function call a function in which you can call CallCtrlCallback()
3) use the windows events and catch them with a specific callback.
a écrit dans le message : 7o714u$k4c$1@nnrp1.deja.com...
> cause and EVENT?
> In article
> the
> cut
> > B
[Attachment Pierre DURIEZ.vcf, see below]
(4,477 Views)
In article <7nprrj$o82$1@nnrp1.deja.com>,
Just call the function with it's name without CVICALLBACK.
Give care about the parameter oif the function IF you need them inside
the function. Often it is sufficient to replace the 'event' by
EVENT_xxxxxxx constant you have used inside your function code, replace
the values you have not used by 0 or 1
Good Luck
Urs
(4,477 Views)
