LabWindows/CVI
CVILowLevelSupportDriverLoaded
I am using windows 2000 and I cannot get CVILowLevelSupportDriverLoaded to return a 1 in CVI. I see that I have all the sys files installed. Can anyone help me with this?
(3,244 Views)
Josh,
Try building a distribution kit in CVI. In the distribution kit wizard, select the Low Level Driver Support check box. When you go through the installation procedure, this will add the necessary support files for low level operations. Let me know how everything works out.
Tyler T.
(3,214 Views)
